Coil packs
about four weeks ago my 2003 4.7 2rwd Durango started to miss fire so I changed the spark plugs which did not fix it so I took and had a code reading ran, it come back saying Coil number 2 was miss firing. I went and brought a new coil and replaced it. But after about three days she went back to miss firing. After looking at the coils packs I found out there is a difference between the number the old one is 56028138AD and the new coil pack number 56028138AF. Could the new coil pack be wrong?
It should be the same part, I believe the letter at the end indicates a version number change.
Take your original coil and swap it with one from a different cylinder and see if the problem moves there. It could be as simple as a bad wire / loose connection to that coil.
Also pull the plug and look for fouling, cracks, damage to the insulator, etc. If in doubt at all replace the plug, they're cheap.
Bob
Bob
