Need Help: Another car shuts off question (while turning)
Old Jan 12, 2014 | 02:19 PM
PublicHair's Avatar
PublicHair
Originally Posted by jjjefferson
My take on this...
I also own a 2000 Durango with the 4.7.
If you see fluid...its shot. Mine had fluid come out the back on the wiring harness!!!
If you do need to replace that line let me say this...it is a PITA!!!! you will need a 18MM and 16MM wrench to undo the line. This was one of my first repairs on the Big-D...so I had to buy them....never used the 16MM again. LOL.
I don’t get it. Why did you have to replace the hose? And how is replacing the sensor (where the leak is) a PITA to remove? You just unclip the wire harness, pull out the sensor and that’s it. It took me all of 5 minutes to replace the sensor......
Old Jan 12, 2014 | 05:36 PM
jjjefferson's Avatar
jjjefferson
Default I said....
"If you do need to replace that line let me say this...it is a PITA!!!! "
the PS Hi-Pressure line. Yes...replacing that line is a PITA. The sensor is easy...but the line is not. If the line is where the leak is....then it needs to be replaced. Both my line AND my sensor were shot.
Old Jan 13, 2014 | 11:20 AM
whdigital's Avatar
whdigital
Originally Posted by PublicHair
Sounds like the common power steering pressure switch is leaking (needs replacement).
IAC or TPS can cause stalling.
Crankshaft sensor is a pain in the *** to replace. Mine threw a code when it was going bad. I replaced. And it wasnt pretty. If you can, drill a small hole and then screw in a heavy duty eye bolt. Attach chain or sling. Two guys to pull heavy and hard and it will pop out.
Intersting... I was charged 1 hour labor for replacing mine last year. They acted like it was no big deal and they see them go semi-often on these cars.
Old Jan 13, 2014 | 01:51 PM
PublicHair's Avatar
PublicHair
I assume that's in reference to the crankshaft sensor?
If so, they may have a special tool to extract the sensor. It's common read to hear about the end of the sensor breaking off leaving the other half wedged in the block. It's such a tight fit.
I had to use a block of wood and a small hammer to pound the new one in.
Regardless I got mine out within an hour
Old Jan 13, 2014 | 10:28 PM
that_guy's Avatar
that_guy
The 4.7 must have a different sensor. When I changed mine it took less than an hour to remove the hold one and get the new one installed, which included taking off the wheel and fender well liner to get access.
