no bus error
Old Jan 19, 2014 | 05:57 PM
backroadsltd's Avatar
backroadsltd
Default no bus error
I have a 2003 Durango that had ran fine. 4.7 with 129615 mileage It now shows the "no bus" with all that goes along with that issue : no gauges, wandering shift indicator. It will start and run fine. I have replaced the PCM(remanufactured unit) ,the crank sensor,and the throttle position sensor-both new.What do I try next ?
Old Jan 19, 2014 | 07:06 PM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
You forgot the Cam sensor, MAP sensor, AC High side transducer, all of the O2 sensors.
JK. If the truck starts, I doubt it's a powertrain BUS issue. Mess around with your instrument cluster connectors and check EVERY fuse.
