level kit
Old Jan 27, 2014 | 11:00 AM
jamesneon2003's Avatar
jamesneon2003
Smile level kit
do they make a level kit for a 1998 4x4 Durango.
Old Jan 27, 2014 | 02:28 PM
cmikolajczyk's Avatar
cmikolajczyk
Two ways to lift the front: Turning the torsion key to raise the front end, or buying an aftermarket torsion key to give you lift.
What exactly are you wanting to do?
Old Jan 27, 2014 | 03:46 PM
jamesneon2003
Smile
I just want to lift front a couple inches nothing fancy
Old Jan 28, 2014 | 12:13 PM
cmikolajczyk
I have the same truck, and it's already pretty level stock. And with my shocks going out, the front actually looks higher. But if you search the words "torsion bar lift" here on the forum, you can find the specifics. All you need is a ratchet with I think a 18mm socket if you want to crank the front end up with the factory key, but it'd be better I you had the money and time to install an aftermarket key.
