Tccm.
Old Feb 5, 2014 | 12:30 PM
CALIBER 308's Avatar
CALIBER 308
Default Tccm.
How hard is it to change it? Today it is -15 below Zero. I started my 2001 Durango R/T up this morning and the 4 Wheel Drive Service Light came on. I can not change from AWD into 4-Wheel High or Low because the switch along with the Indicator Lights are not working. We have a lot of snow on the roads, and I do need to fix this as soon as possible. Also, if might be a Fuse. Where would it be located? Any help would be appriciated.
Bill
Old Feb 5, 2014 | 02:47 PM
hydrashocker's Avatar
hydrashocker
Most likely it is a bad connection at the T-Case. Check and clean corrosion. Sometimes it helps to unplug and replug a few times to get a good connection.
Old Feb 7, 2014 | 12:28 PM
CALIBER 308
Thanks for the information. As soon as it warms up a little more, I will give it a shot.
Bill
Old Feb 13, 2014 | 01:15 PM
CALIBER 308
Default Tccm fixed!!!!
Finally. After the Four-Wheel Drive problem, I got a P0037 Code and still no Four-Wheel drive. So I replaced the Rear O-2 Sensor and took it for a drive. Good driving lasted for appox. a half a mile, then it started to miss and backfire. Searched for P0037 on the Dodge Forum. Well, after doing some reading a member suggested checking the Battery Terminals. That was it!! The Positive terminal was really caked with corrosion. Now I have Four-Wheel drive and my Durango is not missing or backfiring anymore. A big thanks to members on the Dodge Forum.
Again, thanks a ton,
Bill
Old Feb 13, 2014 | 01:27 PM
CALIBER 308
delete
Last edited by CALIBER 308; Feb 13, 2014 at 01:58 PM. Reason: Please cancel this reply.
