Top dash pad removal
Old Oct 13, 2005 | 01:12 PM
amx1968's Avatar
amx1968
Default Top dash pad removal
Has any one removed the top dash pad ( crash pad) on their Durango? the main one that runs from driver side pillar across top of gauge cluster to passenger side pillar post, need to remove so I can fix dash material curling loose because of Texas heat right in front of gauges towards front window. How do you remove completely I see the screws at top of cluster where else? Thanks for any information that can be shead on this problem.
Old Oct 15, 2005 | 02:16 AM
smokester653's Avatar
smokester653
Default RE: Top dash pad removal
When you find out let me know too. I just found that mine has "bubbles" in it in a couple of places. It almost seemed like it happened overnight. Post how you repaired it also if you can. If I get mine repaired quickly I'll let you know.
Old Oct 13, 2006 | 12:58 AM
superkid778's Avatar
superkid778
I have the same problem. I need help locating all the screws. How did you guys fair?
Old Nov 27, 2006 | 07:51 PM
wagmc's Avatar
wagmc
you have to remove the entire dash assembly to get the "top" off.
I had good luck with contact cement, a small brush and standing on the running board to look through the windshield.
I also used a large bore needle and syringe (turkey marinade injector) to apply glue under the material. if you do this, be careful to push out any air through the needle hole. I was able to reach about an 8" dia area doing this. cleaned up with lighter fluid. all I'm left with is 2 small "nicks" where the needle went, and it's hidden behind the "hump" over the instrument cluster.
Old Jan 11, 2007 | 07:05 PM
cstradling24's Avatar
cstradling24
ORIGINAL: wagmc
Hes right. The steering wheel has to be lowered and the car will be striped to the fire wall when your all done. I had to replace the evaporator core and that is on the fire wall so I had to take it all out and I then noticed its all one piece. the screws you see are helping hold the WHOLE dash to your firewall/frame.
