hi from ky Steven meek. need 411
Old Mar 14, 2014 | 04:47 AM
smeek66's Avatar
smeek66
Originally Posted by DyingBreed
How about keeping your posts in one thread instead of multiple threads for the same issues. Keeps the confusion down and you are more likely to get help instead of clogging up the forum with several threads for the same issues.
ok sorry Not real good at explaining things and New to this
Wasnt sure hows it works
Old Mar 14, 2014 | 06:25 AM
smeek66's Avatar
smeek66
The cams and flywheel are correct. Is there anything Else that could cause a no signal i did remove the negative side of battery
Old Mar 14, 2014 | 12:47 PM
hydrashocker's Avatar
hydrashocker
Try the PCM connections.
Old Mar 14, 2014 | 12:49 PM
hydrashocker
If the cams weren't aligned at TDC cylinder they could be off causing the code. Check the wiring and harnesses.
Old Mar 16, 2014 | 06:10 PM
smeek66's Avatar
smeek66
Originally Posted by hydrashocker
What codes?
Start over and retracing my steps i found it still codes camshaft Sensor p0340 i got 5 volts coming in to the Sensor but the sparkplugs are Not firing i have replaced the crankshaft sensor 3 times to Not sure Where to look now
Old Mar 17, 2014 | 12:24 PM
hydrashocker
If you're sure you have the timing correct, and correct parts, then for some reason the system isn't reading the perimeters. Do a PCM reset and try again. You might need to take it in and put it on the OBD II to read it.
To reset;
Remove the negative terminal of your battery (10mm wrench).
Turn on your head lights.
Turn your ignition key to START and hold it there for about 15 seconds.
Turn your ignition key to OFF and remove it.
Turn off headlights.
Connect the negative terminal of your battery.
Start but do not hit the throttle. Idle for about 10/15 seconds then turn off.
Restart the truck and drive as usual. It will take at least 12 starts and 48 miles to fully retune the computer. Hard Codes leave a shadow for 40 full cold starts.
Old Mar 19, 2014 | 07:21 AM
smeek66's Avatar
smeek66
To reset;
Ty for the Info still no firing i am done Not sure whatelse To Do other than junk it someone told me might be a short or a ground it did Run but just died On me so Ty u all
Old Mar 19, 2014 | 10:55 AM
hydrashocker
Well you could have a shop read it and figure out what's not reading or timed correctly. Either way good luck.
Old Mar 20, 2014 | 06:59 AM
smeek66's Avatar
smeek66
and can't afford to take it to a and can't afford to take it to a shop and t and the timing is correct checked it but thank you for all your support
