New Member Have Question
Old Mar 11, 2014 | 09:07 AM
Mdhum0315's Avatar
Mdhum0315
Default New Member Have Question
I have recently purchased a 1999 Durango, and after a few days noticed the heater does not work. If the dial is turned to heat on my panel, I have also noticed a white mist coming out of the vents. There is no smell, and the floorboards are not wet. It almost always only happens when the dial is turned to heat (the a/c works fine), but occasionally it will also happen when idling at a stoplight or stop sign. Any ideas of what this may indicate?
Old Mar 12, 2014 | 05:29 PM
hydrashocker's Avatar
hydrashocker
Check the coolant level first and foremost.
Next you could have a bad heater core.
