Air Flow Sensor
Old Apr 18, 2014 | 03:32 PM
Bimmer's Avatar
Bimmer
Default Air Flow Sensor
Do we have such a critter? I'm curious as I'm about to replace the plugs because it's been over a year and usually in my former Ranger when I replaced plugs, I'd also use MAF cleaner on the sensor. I did a search here for MAF and then MAP but didn't get anything back so thought I'd ask those more knowledgeable than myself.
Thanks!
Old Apr 19, 2014 | 03:01 PM
pkucan's Avatar
pkucan
Went online to rockauto and they show a Manifold Pressure (MAP) Sensor for the 99!
Old Apr 19, 2014 | 03:15 PM
dxloat's Avatar
dxloat
I personally wouldn't replace them unless needed, too much $ to throw away unnecessarily. They also last a lot longer than a set of plugs generally.
Old Apr 19, 2014 | 04:01 PM
hydrashocker's Avatar
hydrashocker
No don't worry about it. Your older Ford has a sensor that monitors all the air flow that goes through the intake, these do not. It's done by a vacuum type sensor on the outside of the throttle body, and manifold sensor works on temp.
Old Apr 19, 2014 | 06:54 PM
Bimmer's Avatar
Bimmer
So there's no cleaning of buildup necessary anywhere in the intake emissions?
Old Apr 19, 2014 | 07:52 PM
that_guy's Avatar
that_guy
Clean the throttle body and the IAC, but that's about it.
Old Apr 21, 2014 | 09:06 AM
hydrashocker
+1 on that.
