Problems on 2003 Dodge Durango SXT
I replace the calipers, brake pads, and rotors on it. It still shake bad when hit the brakes and brake pedal feel like it warp again and it shouldn't be because everything is new. Do anybody have this problem?
If you did not grind flat the knuckle slide arms where the pad arms slide and lubricate this area brake arms can get stuck in old groves and come in sideways. It results in cracked pads.
Just because you have new rotors doesn't mean they are not true, you should have them checked for shelf warp and remember to clean the oil off them prior to install.
