Electrical issues??
Old May 15, 2014 | 12:57 AM
403Phaze's Avatar
403Phaze
Post Electrical issues??
I recently installed a sub, wired with fuses and proper ground (self wired)
its been about a week since the install and a couple of days ago it started acting weird,
the Battery gauge went from being in the middle to completely dropping to the left (dead) but i still had everything lights, sub....
if i turn the ignition off, then on again it works fine with no issues,
and today, most recent issue, but most major...
my check engine light came on, the fluid levels are great (oil, coolant, washer, ps....) i have no issues with studdering or bogging, or fluctuating RPM's
im not sure what could be the issue, battery was purchased under a month ago, only thing i haven't checked was Alternator or starter, but they have not given me issues
does anyone else have an idea on what could be causing this?
Old May 15, 2014 | 01:55 AM
winkie74's Avatar
winkie74
All kinds of things can happen with electrical wiring especially when you add electrical accessories. First find a friend or go to a parts store and see if you can borrow a code reader or have a shop read the codes that turned on your check engine light.
Old May 15, 2014 | 08:25 AM
that_guy's Avatar
that_guy
Yeah, figure out what the code is for and let us know. Disconnect the power wires for the sound system from the battery and see if things are still acting up. That'll at least help you narrow it down.
Old May 15, 2014 | 09:43 PM
moe7404's Avatar
moe7404
i would check the grounds first. IDEA: move the ground all the way the bat NEG post. my dad had a saying " all ways check the last thing worked on."
Old May 17, 2014 | 04:54 PM
403Phaze's Avatar
403Phaze
soo, found the issue, my alternator failed, on a drive to the next town 130km away, everything died after battery drained, no electricity is NOT fun when your doing 120km/h on the highway, anyways replaced the alternator now runs great!
thanks guys!!
Old May 17, 2014 | 05:14 PM
that_guy's Avatar
that_guy
Yeah that's no fun. My alternator crapped out last month, but luckily I noticed the gauge never came up before I pulled out of the driveway, so I just went to autozone and had them replace it under warranty.
