need help with brake light switch
Old May 16, 2014 | 03:45 AM
ter666's Avatar
ter666
Default need help with brake light switch
What's the trick to disconnecting the wire harness from the brake light switch on a '98 Durango?
Old May 16, 2014 | 08:18 AM
JeeperDon's Avatar
JeeperDon
Most of the connectors have a double lock. A tricky little red or yellow plastic thing has to be unlatched and slid out of the way to allow the main lock to be pressed.
Old May 16, 2014 | 12:30 PM
ter666's Avatar
ter666
Thanks for the response, but your description doesn't match my connection. I attached a picture of it. I tried pressing in on the green tabs, but no luck. What am I missing?
Attached Thumbnails need help with brake light switch-brake-light-switch.jpg
Old May 16, 2014 | 04:09 PM
gnelson49's Avatar
gnelson49
Rather than pressing in have you tried prying up the green tab in the center. It may be a lock down connection once you reconnect the harness to the switch.
Old May 16, 2014 | 04:43 PM
ter666's Avatar
ter666
Tried, no luck.
Old May 28, 2014 | 02:26 PM
hydrashocker's Avatar
hydrashocker
It is a quarter turn then pull up on the older Durangos, not sure on 2001-2003 but I think it's the same.
Old May 29, 2014 | 10:14 AM
ter666's Avatar
ter666
Update...turns out there isn't a trick at all. It should have just easily pulled out. The connecters had welded together and I was fighting a lost cause. I had to cut the old wire harness off and splice in a new one (kit from dealer). Installed new switch and everything is working fine. Thanks for all the suggestions.
