A Few Maintenance ???s
Old Jun 7, 2014 | 01:27 AM
thurd94's Avatar
thurd94
Default A Few Maintenance ???s
1998 5.2L Back and running perfect after electrical. Well we have been avoiding it so far, but definitely needs every single bushing I can think of.
1. Does anybody know where I can get a full kit? Rather than separate kits for different spots.
2. And the other thing is we went camping, truck got stuck, we got it out (front tires were buried roughly 6 inches and would not spin in 4wd), but 4L is shot now. I believe it is NP242 transfer case. 2Hi, 4Hi part time, N, 4L part time. Sometimes I had to hold floor shifter in 4L, and it would yank out of my hand. Pretty loose shifting arm now. I read about Drivetrain.com, may have to rebuild the T-case. Have not gotten under the truck to look.
3. We replaced back brakes last year. I know we did not do them too tight, truck sat 8 months, now one side I can not pull the drum off. No slot in back to loosen. Bled brakes, didn't help. Shoe only rubs drum on a small spot, not on the entire shoe.
Old Jun 7, 2014 | 10:20 AM
that_guy's Avatar
that_guy
Sounds like you've got the nv231 then if you don't have the full time position. Check the grommets in the 4wd shifter linkage.
Old Jun 16, 2014 | 02:35 AM
thurd94's Avatar
thurd94
Sorry 'bout the wait. I haven't checked the grommets just yet, taking a trip to Colorado this week so don't want to mess with anything. Did just have to replace the starter, bad solenoid, and bolts because Chapman stripped the starter ears. I have noticed when I drive that it sounds like a bearing is spinning freely near the mid-under section about where the transfer case is.
