Cylinder 4 misfire
Old Jun 10, 2014 | 10:42 AM
Tuffmudder1991's Avatar
Tuffmudder1991
Default Cylinder 4 misfire
So I got a 99 D with 5.2 slt. It has a p0304 I've replaced the spark plugs (checking the gap) wires cap and rotor. New map sensor tps, and upstream 02 sensor. Couldn't break the downstream loose. I just redid the head gasket, and injectors. I don't think it's fuel or spark related, I'm thinking it's the lower o2 or the computer. Every so often this code will disappear, but it still has the miss. I'm getting 13 mpg at the moment.
Old Jun 10, 2014 | 06:14 PM
dolittle's Avatar
dolittle
If the P0304 code is the only one you have I don't think it is an O2 sensor.
My guess would be the injector. You could switch it with another and see if the code moves with it.
Old Jun 11, 2014 | 07:19 AM
SmokinJoe02's Avatar
SmokinJoe02
Could be a bad plug out the box. I'd buy another one and try that.
SJ02
