Cold in front, warm in back
Old Jun 26, 2014 | 10:03 AM
that_guy's Avatar
that_guy
I'm not sure how everything is with the rear ac setup. The FSMs in the diy section should have all the instructions, so you can see if it's something you want to tackle or not though. You will have to drain the system to work on it, and technically you're supposed to have a shop do that and recover the refrigerant. After you're finished you'll have to have a vacuum pulled on the system before it's refilled.
