Replacement leaf spring bolts
There are times where I use OEM parts too, but sometimes the aftermarket parts offer some advantages, such as not having stupid f'ing torx heads.
Not to mention I can't even find a picture of that bolt if I search for that part number online, so I don't know if it's even the right one or not until I see it.
As for not finding a picture, best I can do is the catalog illustration, if it's a '99 Durango and you're looking for #16 in this picture then the part number I posted should be correct.
-Steve
Heck, I've abused trucks I've built with grade 5 bolts for the springs.
Its not like your actually going to break one.
Grade 5's will bend before they break.
Grade 8's will just break. Not intended to bend.
I work on heavy trucks and equipment for a living.
All frame bolts for cross members, suspension brackets, pump mounts, etc etc. All get grade 8.
But grade 8 for springs on a little pick-up. Sure. I would but only because I'd get them free from work.
But grade 5 never failed me.
Well, they did on my winch bumper once. Only once.
Four 3/8 grade five were replaced with six 1/2" grade 8.
But factory bolts at $6+ each?
Im way to cheap for that crap. I'd use a peice of rebar stuffed through and bent so it won't fall out before I paid that much for a bolt.
When I pulled out the spring bolts on my 2001, the bolts had a shoulder on the edges so it fit snugly inside the bushing. The bolts where the shackles mounted to the frame were just regular bolts. I really wish I would have taken a picture of them when I had the chance.
When I replaced them, all I used are grade 8 bolts with some washers and red loctite.
I don't snug them down a lot or use locktite, instead I just use nylon lock nuts and a snug fit (I can still put a wrench on the bolt head and rotate the bolt), have done it that way for years. I beat the crap out my Jeep on rocks and at max flex and never had one loosen up.
