Front wheel tilting over and hitting New hub bearings
Old Oct 28, 2014 | 08:17 PM
durangotango98's Avatar
durangotango98
Unhappy Front wheel tilting over and hitting New hub bearings
I just replaced the hub bearings on both front wheels, Now the ABS system is going all weird and the drivers side wheel tilts in when turning and hits the what ever tats called that holds the thing for steering. ????????? Now what do I check next
Old Oct 28, 2014 | 10:02 PM
dxloat's Avatar
dxloat
Gotta be honest, what you describe sounds bad. Do you run oversize tires? I think the thing you are trying to say is hitting is a tie rod end maybe. I'm going to guess bad ball joints, but I would think you would see that when you replaced the wheel bearings. By the way ball joints are about the weakest link in our front end.
Old Nov 1, 2014 | 08:36 PM
durangotango98
i have 31 10.50 15 tires brand new set
Old Nov 1, 2014 | 09:43 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
i would second the balljoints guess, especially if you still have the factory rims on the truck, sounds like a serious problem that i wouldnt drive any more until i got it fixed.
