2002 Durango 4.7 Evap Can Purge Sol Fuse
Old Nov 6, 2014 | 05:27 PM
leebar's Avatar
leebar
Default 2002 Durango 4.7 Evap Can Purge Sol Fuse
Greetings to all,
My '02 Durango Sport 4.7 engine 4 x 4 has an issue with the Evap Canister Purge Sol (ECPS) as no electrical signal is going to the ECPS. The ECPS coil has an Ohm rating of .14 and I believe the coil is good. Someone had mentioned that the fuse for the ECPS might be blown and needs replacing causing a P-0440 code. Does anyone within the Dodge Forum know of a fuse for the ECPS and where it is in the system to replace?
QUOTE: Also make sure that the fuse to the purge solenoid has not blown, as this will send the fault code even after you replaced the purge valve.
Thank you in advance for your suggestions.
Leebar
Old Nov 6, 2014 | 05:58 PM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
Make the sure the 2 hoses going to it aren't flipped around backwards. The purge valve should be marked CAN VAC or both. I see that a lot.
