P0340
Hi, hope you guys can help me. i have a 2000 Dodge Durango 4.7L V8 4x4. and have a P0340 code that came up, i know it is camshaft position sensor, i replaced it last year. this time i replace the crankshaft sensor it didn't fix it. will a sensor i replaced last year go bad already? also does anyone one the location of the camshaft position sensor circuit bank 1 sensor 1? the one i changed last year is the one located on the front right cylinder head is that circuit bank1 sensor 1? and if so where is bank2 and so on? actually how many sensors is there?
P0340 No Cam Signal At PCM
Drivers side should be bank 1.
You MUST disconnect the negative battery cable and isolate it before removing these type parts or risk a surge damaging the sensor. I have seen far too many people not disconnect the battery and the new sensors fry.
Cam sensors (2) I believe is on the head, front, outside, and monitors the sprocket on each head on the 4.7L.
Crank shaft sensor is on the passenger side, lower left engine block on the 4.7L.
I did not use Mopar parts. Went to AutoZone (Duralast) brand! Didn't really think it would make a difference but I guess it does.
I used one of those on my 03 4.7 and it lasted all of 3 months. Went to the stealership and got the part and haven't had an issue since.
