My durango didn't like cold weather.
Old Jan 19, 2015 | 01:18 PM
vako's Avatar
vako
Default My durango didn't like cold weather.
When I drove up north, my durango whining loud on big turns. Also coming back serious problem started. Every time I braked at 75 mph wheel would wobble, before I left I had both front and back different oils changed, balance, rotation and alignment ,
Old Jan 19, 2015 | 01:56 PM
that_guy's Avatar
that_guy
Where did the whining seem to come from? The wobble might be brakes.
Old Jan 19, 2015 | 03:01 PM
vako's Avatar
vako
I don't Care much about the whining noise it's probably power steering going bad, just was worried bout the steering wobbling on brake, gonna take it to shop, but I'm pretty sure it's prob brakes , they were working harder in the hills, I wasn't going down hills on brakes but pretty sure they still took more than usual beating
Old Jan 19, 2015 | 03:06 PM
hydrashocker's Avatar
hydrashocker
They also could have not put friction modifier in the rear differential if you have a Limited Slip rear end. That will give you a whine and shatter when you make hard corners.
Could be a loose lugs. Your supposed to re-torque them after 25 miles when they mess with your tires. Also could have a warped rotor.
Further they could have left something loose, like a control arm bolt. Take it back!!!!
Old Jan 22, 2015 | 04:18 PM
vako's Avatar
vako
no i specifically told them i had limited slip in the rear and to make sure to add that. but the mechanic was also telling me that there was one in the front also.. i was telling them no way, dodge never made front lsd for durango. anyways it turns out my front rotors were wraped.
Old Jan 22, 2015 | 05:12 PM
hydrashocker
Woop, nailed another one.
