99 5.9 p0505 wtf?
Old Jan 31, 2015 | 05:20 PM
winerig's Avatar
winerig
Default 99 5.9 p0505 wtf?
Replaced iac, cleaned throttle body, new battery, new terminal connectors.engine will idle perfect and no check engine light, when engine is warmed up take it for a drive and check engine light comes on, then it will idle a little high. Suspended insurance almost a year ago due to this issue, have read every thread I could find and symptoms always seem different from mine. This is driving me nuts! I want my rig back.
Old Jan 31, 2015 | 08:37 PM
dxloat's Avatar
dxloat
You need to hook up a scan tool and pull the code your D is throwing to light the service light in the first place.
Old Feb 2, 2015 | 12:51 PM
winerig's Avatar
winerig
It's been the same code-p0505, IAC code. Sometimes it's there when I start the engine sometimes its not, it always pops on after driving for a bit.
Old Feb 5, 2015 | 04:12 PM
hydrashocker's Avatar
hydrashocker
Go to a junk yard and pull a new Throttle Body, clean it and install. Sounds like you have an air leak somewhere. Remember to use a new gasket. Check all your vacuum lines as well for cracks.
