Need help!!!
Old Feb 12, 2015 | 03:23 PM
Anthony06's Avatar
Anthony06
Default Need help!!!
This is for my mother, she has a 2000 Durango R/T, about 137,000 miles.. 1st- the shifter on the floor for 4wd hi, lo is stuck in 4hi she thinks, at the same time that happened she lost reverse too, every other gear is fine, and she claims when it's in reverse, the steering wheel moves but the tires don't... Never heard of that, don't know if she getting old or what... Any ideas??
Old Feb 12, 2015 | 04:31 PM
That makes no sense at all. Can you go look yourself?
Old Feb 12, 2015 | 05:37 PM
Anthony06's Avatar
Anthony06
Nah, I'm in Minnesota, she's in Pa... Yeah, I don't know about the whole steering thing, but she def. has no reverse, even when they tried to push it in Nuetral, truck won't budge... Mechanic today said her tranny is shot... She needs a new or rebuilt one.... How can that be if all the gears work except reverse
Old Feb 12, 2015 | 06:44 PM
What were the events leading up to this? Maybe she got stuck and burned the transmission up trying to get un stuck?
Old Feb 13, 2015 | 06:58 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
its a common failure mode to lose reverse and have everything else work and the trans needing a rebild (or replacement)
Old Feb 15, 2015 | 01:58 PM
that_guy's Avatar
that_guy
If the drivetrain is bound up it might not want to shift out of 4hi until it can roll some in neutral. 4hi is only suitable for use on slippery surfaces (off road). Being that R/Ts have the full time transfer case it should be in the AWD or 4WD position for normal use.
Old Feb 16, 2015 | 12:42 PM
Anthony06's Avatar
Anthony06
Thanks everyone, she had a couple mechanics look at it, they all say she needs to rebuild or replace tranny
