engine idle and transmission have mind of their own
Old Mar 19, 2015 | 03:10 PM
baffled's Avatar
baffled
Question engine idle and transmission have mind of their own
01 Durango slt 4.7l idle races or low idles on its own after driving on the highway for an hour or so and at the same time the transmission just stopped working then would engage but wouldn't upshift except occasionally all the while the engine is doing whatever it wants without anyone even touching the pedal. Anybody?? Ideas????? Never seen anything like it in all my years
Old Mar 19, 2015 | 09:34 PM
Old_School's Avatar
Old_School
Bad TPS? Bad battery connection?
Old Mar 20, 2015 | 09:09 AM
baffled's Avatar
baffled
The tps is something that came up quite a bit on my internet searches .... it's my gf's truck and I just spoke to her and she said that after letting it sit a few hours she got in it to move it and it started fine she put it in drive and it seemed to respond ok but when she put it in reverse to back it up she said the engine started racing to like 3500rpm's and she had to practically stand on the brakes to keep it from taking off and that the brakes could hardly keep the rear tires from turning
Old Mar 21, 2015 | 10:59 AM
baffled's Avatar
baffled
Had to move the truck myself yesterday...... got in and as soon as I started it it was just above 2000 rpm's .... let it run for a minute and when it didn't back down on its own I gave the accelerator pedal a tap to see if that would bring it down and instead the engine stuck at about 3300 rpm. Does this sound even remotely familiar to anyone?????
Old Mar 21, 2015 | 12:08 PM
that_guy's Avatar
that_guy
I'd verify that the throttle body itself isn't sticking open. Also if you have a OBD reader you should be able to see the throttle position sensor value.
Old Mar 21, 2015 | 12:13 PM
baffled's Avatar
baffled
Thank you .... that makes sense .....I will keep you posted!
