Why do my new shocks squeak?
Old Apr 24, 2015 | 12:54 PM
rjlane1@pacbell.net's Avatar
rjlane1@pacbell.net
Default Why do my new shocks squeak?
I installed Monroe Reflex shocks a few months ago. I didn't notice it right away, but eventually noticed a squeak coming from somewhere. Making a left turn, going over bumps, etc. It definitely seems to be coming from the right front shock. I couldn't duplicate it on the other three shocks. The installation of these are pretty straight forward, so any idea what could make it squeak like this? Over torqued?
Thanks!
Old Apr 24, 2015 | 05:41 PM
rjlane1@pacbell.net
Nevermind.. I crawled under there and had someone bounce the car for me. Turns out the squeak is actually coming from one of the swing arm joints. I just assumed since I was monkeying with the shocks that I must have done something wrong.
Old Apr 24, 2015 | 07:14 PM
JeeperDon's Avatar
JeeperDon
Hit all the bushings (4 control arm, 6 sway bar, 8 shock, 6 leaf) with a good soak of WD-40, then do it again in a year when it may start to squeak again.
Old Apr 26, 2015 | 07:56 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
i would suggest against wd-40, its a solvent meant for cleaning, its not a lubricant, id use something designed for use outdoors as a weatherresistant lubricant (i like silicone based spray lubes myself)
Old Apr 27, 2015 | 11:59 AM
JeeperDon's Avatar
JeeperDon
Originally Posted by shrpshtr325
i would suggest against wd-40, its a solvent meant for cleaning, its not a lubricant, id use something designed for use outdoors as a weather resistant lubricant (i like silicone based spray lubes myself)
I agree, but it was on the shelf. I first used it to just see what was making the noise, but the stuff lasted a year. Do you have a silicone spray brand you like? It wouldn't be a bad idea to have it on my shelf next time.
Old Apr 29, 2015 | 06:40 AM
shrpshtr325
THE ULTI-MOD
wd-40 makes the can i have on my shelf right now, its been pretty good to me so far
