What is this thing?
Old May 19, 2015 | 02:20 PM
AndyL's Avatar
AndyL
Default What is this thing?
Can anyone tell me what this thing is? It's a white plastic valve that's plugged into a 1/2 in tube that comes up near the battery. It seems to be leaking radiator fluid. I haven't been able to find out what to call it to see if I can get a new one. It has a top that's very loose but can't be either tightened or removed. How would you know if it's broken? Thanks
Old May 19, 2015 | 02:21 PM
Looks like a axle vent. and its probable leaking axle fluid.
Old May 20, 2015 | 11:02 AM
AndyL's Avatar
AndyL
Thanks a lot JKeaton, it the front axel vent. Now that I know I am able to search for solutions. It sounds like cutting a fuel filter into the line solves the weeping problem.
2000 Durango 4.7 SLT 4X4.
Old May 20, 2015 | 11:19 AM
IF its leaking fluid, the axle is likely overfilled. Did you drive through water recently? Or have the axle serviced?
Old May 20, 2015 | 11:26 AM
AndyL's Avatar
AndyL
Yes, at the Pennzoil Speed Oil Change Center.
Old May 20, 2015 | 11:32 AM
Sounds like they overfilled it. I'd take it back and show them. i don't trust those places to put air in my tires correctly.
