problem with abs breaks
Old Jun 24, 2015 | 12:43 AM
zombiewalker's Avatar
zombiewalker
with having running boards it all seems a bit of a tight fit to get the floor jack under the pinch welds I have no problem taking off the running board but any suggestions, I work a lot and don't have a lot of spare time to work on this and using the wifes car that also has it's own issues our dodge is the more reliable of the 2 vehicles
thanks again
Old Jun 24, 2015 | 06:06 PM
zombiewalker
I went to the dealer and they said I can lift the vehicle from these points I was wanting to know that this is correct as I need this to go to and from work pictures below.
It also appears that the help I was given was quick to come but after I ask for what others might call common knowledge there was no help. I can tear down and repair computers no problem I have no issue with troubleshooting this problem with the abs, but when it comes to lifting the vehicle in the correct place everything went quiet.
I have googled and youtubed all that I can and nothing is exactly clear on it.
Thanks for any help
I was told here was ok to use for the front to lift one wheel at a time.
Just under the skid plate in the middle for lifting both front wheels
at the back where the leaf springs are but I wasn't sure exactly this is where it bolts to the axle
