ford taurus electric fan conversion
Old Aug 26, 2015 | 06:05 PM
snipem's Avatar
snipem
also 1 more question. can i use breaker switches instead of fuses or is that a bad idea? oh and where can i get a power distribution block?
Old Aug 26, 2015 | 06:09 PM
that_guy's Avatar
that_guy
I've never really messed with breaker switches. Not sure about the block either... maybe a fuse box for an old car or something for car audio systems.
Old Aug 26, 2015 | 10:24 PM
snipem's Avatar
snipem
ok thanks for all the info and hopefully my electric fan install goes all good. and when its installed ill post pics in a new post as you dont see many conversions with pictures.
Old Aug 27, 2015 | 08:08 PM
snipem's Avatar
snipem
im just curious but do you think my system could handle just using the taurus fan on high speed only instead of using it as a 2 speed fan and only make it 1? and will the 70 amp relay still be a large enough relay? im just wanting to get this on my truck asap even if i can buy the secondary temp switch later.
Old Aug 27, 2015 | 08:23 PM
that_guy's Avatar
that_guy
It should be fine with the high speed only. I'd still do the dual speed though, high speed all the time isn't necessary.
Old Aug 28, 2015 | 08:22 PM
snipem's Avatar
snipem
hey im wondering if i can use 2 maradyne MFA110 adjustable temperature switches at 2 different temperatures, 1 for each fan speed instead of using 1 adjustable switch for the slow and a block mount switch for the high?
