Idle increases when heater is turned on
Old Jan 3, 2016 | 10:19 AM
NCDurango's Avatar
NCDurango
Default Idle increases when heater is turned on
Now that it is getting cooler (heater weather) I noticed that my idle goes up by about 250rpm when I turn the heater on similar to what is expected to happen when the A/C is used. Is this normal?
Old Jan 3, 2016 | 11:18 AM
Did it do it before?
Old Jan 3, 2016 | 10:39 PM
NCDurango's Avatar
NCDurango
Thats part of my problem, i don't remember. I don't drive the D everyday but it has done it for several weeks that i have been paying attention.
Old Jan 4, 2016 | 07:20 AM
Maybe the compressor is kicking on.
Old Jan 4, 2016 | 08:36 AM
JeeperDon's Avatar
JeeperDon
Assuming the A/C compressor is indeed off... There vacuum lines/systems associated with the heat controls. I'd suspect a leak somewhere there, which would cause the computer add fuel to make the mixture right, but the more fuel will make it idle higher.
Old Jan 5, 2016 | 06:40 PM
dolittle's Avatar
dolittle
If the selector SW is in defrost mode then the a/c compressor comes on.
Old Jan 8, 2016 | 01:52 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
dolittle beat me to it, check the position selector
also a 2001 had electronically actuated heater controls, not vacuum
Old Jan 12, 2016 | 10:50 PM
NCDurango's Avatar
NCDurango
So the defrost (both positions) kicks in the compressor? Is this to keep the moisture at bay? I will check to see if the position makes a difference. Thanks
Old Jan 13, 2016 | 07:54 AM
In any defrost position the AC compressor comes on, and yes, it is to remove moisture from the air being blown so it dries off any moisture (fog) on the windshield.
Old Jan 13, 2016 | 05:43 PM
that_guy's Avatar
that_guy
Thought I'd add that if the evaporator core is below a certain temperature (37° is sticking out in my mind) the compressor won't engage, otherwise moisture would freeze and build up, blocking airflow, and causing the AC's low side pressure to drop and the high side to go up.
