Code P0113 after IAC sensor/motor was replaced.
Old Jan 5, 2016 | 11:34 PM
durango193's Avatar
durango193
Default Code P0113 after IAC sensor/motor was replaced.
Hi, I have a Dodge Durango 2000 4.7L 4/4. Initially my problem was my car would turn off when idle, it will turn on every time as long as you press the accelerator, as soon as you take your foot off boom it would turn off. So I read other posts where it would be the TPS and or the IAC sensor/motor (right under the TPS sensor). I had replaced the TPS sensor a few years ago but it wasn't a dealer part it was from autozone. I had cam shaft and crankshaft sensors from there that I had to replace with dealer ones due to recurring issues so I'm doing dealer sensors from now on. But after replacing both TPS and IAC I now have a P0113 code. Could it be a bad IAC sensor? Or is there something that has to be calibrated? The initial problem has been fixed but now this code.
Old Jan 6, 2016 | 12:33 AM
Black02CrCb's Avatar
Black02CrCb
Sorry I have had issues with camera. I think they are finally clear now.
Old Jan 6, 2016 | 01:24 AM
durango193's Avatar
durango193
Cool thanks for the quick response! I'll try to troubleshoot with these techniques. Is that book a work Manual?
Old Jan 6, 2016 | 02:45 AM
Black02CrCb
it is yes, a factory manual. It is for a 2002 Ram 1500 but I am sure it will work just fine for your application.
Old Jan 6, 2016 | 02:49 AM
Black02CrCb
http://www.ebay.com/itm/2000-Dodge-D...10XmQQ&vxp=mtr
http://www.ebay.com/itm/2000-Dodge-D...FTl7EH&vxp=mtr
couple sets, the top is complete, the bottom is missing the brakes booklet, but 50.00 less.
Good luck.
Old Jan 8, 2016 | 03:21 PM
durango193's Avatar
durango193
Good luck.
Great! thanks for the service repair manual links gonna have to get one.
