2003 Durango Electrical Issues
Old Feb 1, 2016 | 04:52 PM
stewie01's Avatar
stewie01
Default 2003 Durango Electrical Issues
I'm currently car shopping, looking at late 1st Gen Durangos, found one at a car lot for $2500.
The bad:
Failed Virginia inspection because the daytime running lights wouldn't stay on. The instrument panel flickers as if a short or loose wire when driving over bumps and the instrument panel back light doesn't work, possible connected to the DRL?
The good, everything else, strong motor & trans, all the options, 4wd works.
I know nothing about Durango's, are any of those issues fairly common?
I don't wanna buy a vehicle to chase electrical issues but if it's something fairly common and easy $2500 is a good price for this area.
Any ideas?
Old Feb 2, 2016 | 05:57 PM
that_guy's Avatar
that_guy
I don't see how you can get failed for DRLs which still over 10 years later aren't required. Only canadian models had them from the factory, and they had a little module in the engine bay I believe. Check the fuses for the lights, check for loose grounds, and check the headlight switch as well.
Old Jun 16, 2016 | 10:05 AM
Schmeezy_Peezy's Avatar
Schmeezy_Peezy
I have an 03 durango and I got it at 168,000 miles and currently have 205,000 with no major problems that weren't caused by me. Very reliable suv
