98 transmission extension housing HELP
Old Mar 7, 2016 | 11:57 AM
robert301972robert's Avatar
robert301972robert
Unhappy 98 transmission extension housing HELP
Hi I have 1998 dodge Durango slt 5.2L 4x4. The transmission extension housing is cracked all the way around it. It was caused by the drive shaft universal joint coming off and hitting the ground. It has a part# on it 19104A My question is. I found one but the number on it says 19104AF will It work for my transmission?
Attached Thumbnails 98 transmission extension housing HELP-12565538_845094982289597_6704428540572726265_n.jpg
Old Mar 7, 2016 | 07:32 PM
that_guy's Avatar
that_guy
The two letters at the end of Chrysler part numbers only indicate the manufacturer of the part. If the numeric parts match it should work. You should have a 44RE transmission, so if the part came out of another 44RE transmission it should fit.
Old Mar 8, 2016 | 07:21 AM
robert301972robert
Well i have a problem now. There is a thrust bearing and thrust washer. In between the over drive piston and the over drive clutchs. How do I keep those In place while I am putting the housing back on. they keep wanting to fall out.
