Hi guys,
I have a 2000 durango with the stock roof bars running driver to passenger side. I want to upgrade the bars to something stronger and flat so I can carry some long trim mouldings from the big box store.
I am going to be adding a T-Load Hitch or Goalpost hitch to give me that third point to load on.
Question is what fits our durangos? Checking out the websites, they all say if I have the factory rails that run front to back, which ours don't. I have never seen a 1st generation with bars like that.
Anyways hoping someone with some knowledge can shed some light here. I am hoping that I get a set of thules or rhino-rack bars and they plug right into the factory hook in rail.
Anything you mount to the stock roof side rails aren't far enough apart to adequately hold floppy moldings. The rack type won't help that. You'd be better off bungeeing/mounting a couple PVC pipes to the stock bars and putting the molding inside those.
Probably should have mentions its pvc trim boards. Something like 18' x 1" x 5".
I am thinking about adding a hitch to my front and putting up in a goal post hitch similar to this.
Quote:
You never said this was an ongoing project, wrote it up as just a one time haul. As such, I just pointed out your 'I have to use my Durango, make it work no matter what!', is likely not the best approach. Originally Posted by fcastro
Ok, well obviously I trying to find an answer to my original question and not looking for dumb suggestions on here.
Good luck with your adventure.
Honestly I would borrow a car trailer from someone, less likely to damage the boards. Just plan out everything so you hopefully only have to make one trip with it. To answer you question I can't say that I have seen any aftermarket racks for these.
