I pulled a wire and Im not sure where it belongs
Old Jun 5, 2016 | 11:12 AM
Dawged's Avatar
Dawged
Default I pulled a wire and Im not sure where it belongs
Changing out the heater and evaporator core on my 98 Durango I noticed a wire and was pulled from something and I'm not sure where it went.
Im not sure if its the computer or not but the device mounted under the center console, below the middle of the dash had 2 cables coming down to it.
One cable has all the wires that plugs into the device. The other cable has a single wire. That single wire is the one that was yanked from its location.
Anyone have any idea on this?
Once I get it back together I'll take off the radio area of the dash to try and trace it back
Attached Thumbnails I pulled a wire and Im not sure where it belongs-20160605_105922.jpg
Old Jun 9, 2016 | 01:45 AM
Friar Tuck's Avatar
Friar Tuck
Exclamation Airbag Control Module
Disconnect your battery negative cable for a few minutes before plugging this cable in. It goes to your AIRBAG CONTROL MODULE.
That single black wire may have pulled out of a ground lug under the dash.
Old Jun 10, 2016 | 08:15 AM
Dawged's Avatar
Dawged
I knew where the cable plugged into. My problem was where the wire without a connector on it went.
I ended up finding a lug without a wire on it still bolted on. It was a ground.
I took a chance and re connected it. Everything seems to be fine
Thanks for the reply though
Old Jun 17, 2016 | 10:19 PM
Friar Tuck's Avatar
Friar Tuck
Talking
Toldya!
