1998 Durango Non Working AC
Old Jun 8, 2016 | 06:39 PM
Str8jkt's Avatar
Str8jkt
Exclamation 1998 Durango Non Working AC
1998 Durango 4X4 5.2L Magnum ..... I purchased this used a couple months ago ... Went to use the AC and noticed no cool air ... Realized I was not even hearing the compressor clutch kick in ... Today I checked it out ... Hooking up clutch directly to power does kick it on ... Voltmeter on wire plug, to the clutch, never shows any voltage ... I took out the AC relay to switch it with another ... When I put it back the clutch kicked in for a second or 2 and turned right off ... I'm thinking it's some kind of safety switch or sensor turning off the power because something is not right? Any ideas?
Dave from Maryland!
Old Jun 8, 2016 | 08:02 PM
JeeperDon's Avatar
JeeperDon
Check or have checked the freon pressure. Nothing works if the pressure is low. Do a search, there is a lot of info here already.
Old Jun 8, 2016 | 09:43 PM
Str8jkt's Avatar
Str8jkt
I was thinking maybe the Freon was low .... Would that make the clutch shut off as soon as it kicks in? ... Any idea what the pressure should be?
Old Jun 8, 2016 | 11:40 PM
JeeperDon's Avatar
JeeperDon
https://dodgeforum.com/forum/1st-gen...solutions.html
Old Jun 9, 2016 | 12:22 AM
Friar Tuck's Avatar
Friar Tuck
Are your A/C fuses in the JUNCTION BLOCK good? Fuses 1 and 7.
Also, your Ignition Switch has to be turned to RUN for the clutch to be turned on normally.
Old Jun 9, 2016 | 06:51 AM
that_guy's Avatar
that_guy
I'd check the a/c pressures with a manifold gauge set (connects to both the high and the low side) to see what's going on. It doesn't have to be an electrical issue it could just be low on refrigerant.
Old Jun 17, 2016 | 10:24 PM
Friar Tuck's Avatar
Friar Tuck
worse case...Clutch is shorted out.
