Are Durango & Dakota Suspension Same?
Old Nov 10, 2005 | 06:58 PM
Al's Avatar
Al
Default Are Durango & Dakota Suspension Same?
Thinking to put some air bags in front and rear of my durango.
But cant find any for the front. All I seem to run into are for the Dodge Dakota. Most of these air kits come with everything you need to install but just want to make sure first.
So is there any possibility to do this to my Durango?
I would appreciate any input.
Old Nov 18, 2005 | 08:24 PM
mtndewnut's Avatar
mtndewnut
Default RE: Are Durango & Dakota Suspension Same?
I am 95% sure that they are the same.
Old Nov 21, 2005 | 05:50 PM
Al's Avatar
Al
So is it possible to add the air bags to my durango?
Which ones would be good to install? Most of the brandname ones dont have any for my truck...but have found some which I never heard of..
Just want to get a smother ride, not much of a off-road adventurer, mostly traveling...
Old Nov 22, 2005 | 07:38 PM
mtndewnut's Avatar
mtndewnut
I can't say that for sure. You would need to contact the dealer to get specs.
Old Dec 31, 2005 | 02:16 AM
fly2crawl's Avatar
fly2crawl
as far as i know the dakota has coil spring front suspension and the durango has torsion bar springs for the front
Old Jan 8, 2006 | 05:44 PM
dodgebrothers's Avatar
dodgebrothers
Hmmm. My understanding is that Durango suspension is closer to 1500 level pickup of same year.
Old Jan 22, 2006 | 01:13 AM
Amaloney's Avatar
Amaloney
The durango does have torsion bars, I am pretty sure. There was something abotu late 90's models having the same but heavier than the dakota's but I do not know the truth of that.
Old Jan 22, 2006 | 08:42 AM
fredd00's Avatar
fredd00
up front it's torsion bars on a 2000 durango
Old Jan 23, 2006 | 03:28 AM
89Daytona's Avatar
89Daytona
The first gen Durango is on a widened Dakota chassis. http://www.allpar.com/model/durango.html
The shocks for the 97-04 4wd Dakota are the same part numbers as for the 98-03 4wd Durango.
You could get 9-way adjustable shocks if all you want is a smoother ride (like the Rancho RS9000X Shock Absorber Series). The adjustable shocks would allow for you to adjust the ride stiffness and there are in-cab remote adjust controllers available for the Rancho RS9000X series. http://www.gorancho.com/products
Old Jan 26, 2006 | 06:24 PM
robust57's Avatar
robust57
they are different but similar in places. Torsion bars in the front on durango. The rear is different in the fact that the durangos have the leafs mounted on the bottom of the axle and the dakotas have them on the top. Similar to the flip kit provided by the tuff country 5.5 inch lift kit for the durango. No input on air ride though.
