Pushrod length confusion
Old Sep 19, 2016 | 01:06 PM
Chris F's Avatar
Chris F
Default Pushrod length confusion
Looking for some help with a bunch of valve train noise. I rebuilt the 5.2 in my 1998. This was my first engine rebuild (take this into consideration). The first week running my motor it was pretty quiet. Second week I started hearing some valvetrain tapping. (Both sides). Third week the motor sounds like a diesel. I threw in some Lucas Oil stabilizer which quiets things down until the motor gets hot.
I think I installed the wrong length pushrods or something. I put on some EQ Heads and the Hughes 9703 Cam. Everything else including the rockers are stock. I used some trick flow 7.000 pushrods. 7.000 was the measurement I came out with using a checker tool.
Contacted Hughes and they said I should be using stock length pushrods. Stocks are shorter than 7.000, right? Wouldn't the valvetrain noise be even louder with shorter rods.
Does anyone have any advice? Maybe I checked my length wrong. I couldn't find much on checking for pushrod length using the stock pedestal rockers. Also the book I was referencing during my rebuild said to simply torque the rocker bolt down to 21 ft lbs. Thats it. Is that correct.
Old Sep 25, 2016 | 04:50 PM
adukart's Avatar
adukart
Recheck the torque also if they say use factory rods try it. The cam you are using lifts more than factory, so therefore a shorter push is needed. If they say factory works and the factory ones won't I would contact them again but try them first.
Old Sep 25, 2016 | 04:56 PM
adukart's Avatar
adukart
Also with the 110LSA on that cam and the high lift I would get some one to tune it.
