torsion/shackle lift
#72
Ok duranged......that is a sick ride !!!!
Have any more pics of underneith and of the front as well ??
What shocks did you use, were they just the standard stock ?????.....
And did you only use the rear Shackle adjustment, or did you use b/l as well ??????
Also your rear axle is above the leaf springs as well as mine, and mtndewnut has his below the springs ??????
#73
#74
#76
thenyscrod Ok duranged......that is a sick ride !!!!
I didnt run ext shackles when i swapped my leafs (due to snapping abuse 1rst pics) because it would of lifted past my budget( Tires looked to small 2nd set Pics) and i ran extended shocks due to the way i set up.
The older style MTR's were A+ in every situation other than noise after awhile. I ended up dropping them in turn for some Hankook which now i'd take over the MTRs
#77
