radio install 2000 durango
i think its supposed to say IOD or ignition off draw, its basically stuff that needs power even when the key is out of the car, power locks, CTM, dome lights ect.
however the amp not powering up is a different issue, if its the factory amp and you changed the headunit you didnt connect the power on signal wire to the amp properly, if its an aftermarket amp then you can check for such a signal wire, as well as power and ground to the amp (and the associated fuse)
