5.2 pcm in a 5.9
Old Apr 4, 2017 | 04:02 PM
Artilleryman's Avatar
Artilleryman
Default 5.2 pcm in a 5.9
Question, I have a 99 4x4 SLT durango with the 5.9. My PCM went bad in it, I have a 5.2 pcm that I haven't reprogrammed for the 5.9 yet, if I put itbin, will it be okay to run for a little while till I get it programmed? Or will it mess up my truck
Old Apr 5, 2017 | 06:33 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
If it works you will not have the full power available that you are used to with the correct PCM, if it doesnt work the truck wont start. I have not heard of someone trying a 5.2 PCM in a 5.9, going the otherway i have seen work tho so i dont see why it wouldnt. Give it a try and let us know.
Old Apr 5, 2017 | 06:54 AM
Artilleryman
well, it worked, kinda...lol. Truck had the take off of a 4 cylinder, it died several times on me, but unlike with the bad PCM IT started back up. I put the bad one back in and now I just have to get the new one reprogrammed
Old Apr 10, 2017 | 10:48 AM
shrpshtr325
THE ULTI-MOD
glad to hear it 'worked' for ya, at least as a troubleshooting step.
Thanks for reporting back!
Old Apr 26, 2017 | 10:18 AM
mzdeal's Avatar
mzdeal
My 5.9 pcm went "bad" with the "no bus" heat related fault. I replaced it with a used PCM which was a -102 type for a 5.2 4x4. It ran fine for a few years before I got a -147 that works just fine as well.
The only problem I found with the 5.2 PCM was the tranny shift speeds were different. But the wheels were a different size too, so that was most of it.
