2000 Durango Ground Wire Help (By ABS Module)
Old Jul 17, 2017 | 06:22 PM
fcastro's Avatar
fcastro
Exclamation 2000 Durango Ground Wire Help (By ABS Module)
Hi everyone,
I have a loose ground wire near my ABS Pump Control Module. I am pretty sure its a ground. I just tried to connect to the ABS module via DRB-III and got a not connected correctly from the DRB-III. I also heard a clicking over and over. Figured something was up. Sure enough I notice a what I believe is a ground cable hidden on the wires floating.
My 2001 R/T doesn't have this cable. Anyone with a non RT or 4.7 help me out here?
After more searching online I found another thread and the users say it doesn't get plugged in anywhere and to ignore it. But if anyone cares to chime in that would be great. Still can't connect to the module using wiTech.
Old Dec 11, 2017 | 07:21 PM
sporta's Avatar
sporta
Did you ever get a definite answer on this? I am having issue with my ABS module and found the same wire today.
Thanks
Old Dec 11, 2017 | 08:45 PM
fcastro's Avatar
fcastro
I found another thread and basically our trucks come like this from factory.
Old Dec 11, 2017 | 11:13 PM
fcastro's Avatar
fcastro
