2000 4.7 4x4 p0208
i have a 2000 durango 4.7 4x4 skipping and running rough. code p0208 is the only code i get. i have changed the injector #8, spark plug #8, iac valve, and the pcm. it still does the same thing wires seem to be good im just at a loss i need help anything is greatly appreciated
You have already changed the injector, and the PCM.... The code indicates a problem in the circuit for that injector. The only thing that is left is the wiring.........
Go to the parts store, beg/borrow/rent/buy a noid light. Plug it into the injector plug in question, see if you get a steady flash from the noid light.
