99 - Front breaks not releasing
Old Feb 4, 2018 | 01:59 PM
grt's Avatar
grt
Default 99 - Front breaks not releasing
Hi everyone. On my 99 durango the front breaks won't release. Mainly the driver side. With help from a friend, here's everything we've done. changed the caliper thinking it may be bad, blew the lines out, replaced master cylinder, break booster, and the portional valve. None of that worked. I don' know what to check next. 5.9 L with abs 4 wheel antilock
Old Feb 4, 2018 | 02:21 PM
that_guy's Avatar
that_guy
Hoses can act like a check valve when they get old.
Old Feb 4, 2018 | 06:08 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
could be the hoses collapsing internally as suggested above,
could also be worn caliper rails, as they wear in the pads tend to leave a ridge on the rails that they slide on (not a greased pin, the rail is part of the knuckle). You can take a grinder or a file to it and smooth this out, grease it up good and you should be good to go.
Old Feb 4, 2018 | 10:19 PM
grt's Avatar
grt
I did notice the rails did have grooves on them. Wasn' sure about using a grinder on them, so I used emery cloth and elbow grease, and smoothed out the grooves and added grease. I haven't checked the hose's. I'l do that next. A friend mentioned maybe a vacuum leaked. What's your thought on that. Something o forgot to mentioned earlier is after the vehical has sat for a few hrs ( no work being done on it ). You are able to spin the caliper.
Old Feb 4, 2018 | 11:01 PM
that_guy's Avatar
that_guy
That screams bad hose to me if it releases after a while.
Old Feb 5, 2018 | 06:03 AM
shrpshtr325
THE ULTI-MOD
based on that last bit, i agree with That_guy, sounds like the hoses are your most likely culprit.
Old Feb 5, 2018 | 09:03 AM
Ramchu's Avatar
Ramchu
When the caliper is locked up open the bleeder and see if it squirts flood and unlocks.
If it does then it's More than likely a bad hose.
Old Feb 5, 2018 | 10:49 AM
grt's Avatar
grt
I'll check the hose and let you know the out come. Thanks to all for the suggestions.
Old Feb 6, 2018 | 01:07 AM
grt's Avatar
grt
I went ahead and replaced the driver side hose, since I went and got the new anyway. Since everything was new, and it was cheap. Due to being late I hadn't checked to see if that work or not. Here's something I hadn' notice or heard before, while I was pumping the break ( while the vehicle was running ) I could hear air. I used my hand and stuck my down by the break peddle. I could hear air every time I pushed the peddle in.
Old Feb 6, 2018 | 06:45 AM
shrpshtr325
THE ULTI-MOD
the brake booster is vacuum driven, so there will be air movement when you push the brake, its not something i usually notice.
