Front end parts longevity
Originally Posted by that_guy
My moog tie rods were ****. The moog ball joints are still ok though.
One thing I can't seem to find a good replacement for lately is CV axles. Ordered some new ones from advance and got 2 bad ones the first time. I put on of the two replacements they sent on the front and after a month I think it's starting to clunk again.
Seems like there aren't a ton of companies making the axles anymore. The ones I got from advance are rebranded Heri (chinese as all hell) axles. The one I had before that one was a cardone, and it was bad after less than 25k miles. The passenger side still has the original axle with almost 200k miles on it and it has a very slight amount of slop, but I still trust it more than these aftermarket ones.
Another Moog part down. Left Outer Tierod End. I don't actually have record of when I replaced this one but it wasn't that long ago. Called the dealer, outers have been discontinued for our trucks. RockAuto supposedly has Mopar for like $73. Amazon and Ebay for $29.99, I don't trust a 29.99 OTE to be genuine Mopar so I'm not buying that. I looked at Proforged. Supposedly, at least a few years back, they didn't outsource. They're parts are made in Taiwan (or at least were) but they keep good QC in their manufacturing process. Heard a lot of good reviews about longevity. Read on multiple forums about how it's all people will use for front end parts because of the longevity factor. So I have one on order from summit. It'll be installed up against an almost brand new Mopar ITE so it will be a good test to see which lasts longer.
Was just thinking... I use heim rod ends on my Jeep steering, tie rod and drag link. The Jeep parts get beat pretty hard off-roading and have not failed. I wonder how a heim would do for a Durango's rack and pinion. You would have to fab a pair up I suspect. It also requires drilling the knuckle taper to a straight hole, so it's a one-way project. Does anyone know the thread dia/pitch of the stock rod ends?
https://www.dormanproducts.com/gsear...&model=Durango
Just for the sake of argument how often was it greased? Any pics? What actually went bad, you can cut them in half with a saw to see if it was the ball or the plastic socket. I have heard all kind crap about moog but when i got my truck it had 60K on it and the ball joints where history. They where replaced with moog greaseables. I had to replace one because the grease fitting got clogged and no grease got to the ball joint. This was last year with 195k on it. Most of the front end was replaced with moog and no problems at all with them. Moog has different boots that are supposed to better than the standard ones. If water and dirt are getting in them that may be the source of the failure. This topic was on another forum with the same problem with moog and some people went for the XRF ball joints but they also went bad. I would consider looking into swapping them for 2500 truck ends if possible. I'm not familiar with Durango's but there may be a larger ball/socket that will work. I have seen this done on other vehicles. Have you looked at Dorman? They are "supposed" to close to oem but i have no proof of it.
But for now, I sure wish I had a stout factory front end 😂
