Clunking noise in steering column when turning
Old Feb 24, 2018 | 03:30 PM
zbc1998's Avatar
zbc1998
Default Clunking noise in steering column when turning
I have an 02 Durango that has started to have a clunking noise that seems to be eminating from the steering column just behind steering wheel when turning at low speeds. Does anyone have any recommendations of possible cause?
Old Feb 25, 2018 | 08:33 AM
that_guy's Avatar
that_guy
Check for slop in the steering shaft u joints.
Old Feb 25, 2018 | 06:00 PM
b1lk1's Avatar
b1lk1
What he said, definitely the most likely cause.
Old Feb 25, 2018 | 06:47 PM
zbc1998's Avatar
zbc1998
Ok thanks for the info will check them first thing tomorrow
Old Feb 26, 2018 | 08:42 AM
Pspklutch's Avatar
Pspklutch
Only thing I could think of besides the U joints would be the sleeve bolt behind the steering wheel and the pinch bolt at the steering rack/gearbox. Both of those are unlikely culprits, U joints are a much more likely cause, but it doesn't hurt to check if they're tight.
Old Feb 26, 2018 | 01:33 PM
noman's Avatar
noman
I had a issue sorta like that. Kept hearing a clunking and could feel it in the wheel. If I would lift the front end off the ground and set it down the clunking would go away for a while. It was the ball joints the inside of them were torn and every time I turned the wheel I would hear and feel the clunking.
