Trans fluid quantity
Old Apr 22, 2018 | 11:00 PM
Blue Rango's Avatar
Blue Rango
Default Trans fluid quantity
How much fluid do I need for a fluid and filter change? I'm new to the Durango's so not sure which trans I have.
2003 Durango SLT 4X4, 4.7. Approximately 215,000 miles. It"s been running fine and now all of a sudden , it started slipping just once. Seems to shift ok as I'm driving it.
Thanks for any info
Old Apr 23, 2018 | 12:36 PM
Dodgevity's Avatar
Dodgevity
You've probably got the 545RFE. You can generate a build sheet here to be sure.... https://dodgeforum.com/forum/2nd-gen...ur-dakota.html
A single drain and fill will need six quarts of ATF+4. I use Supertech from Wally World.
Old Apr 24, 2018 | 06:42 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
the 4.7 (in these trucks) only came with the 45 or 545rfe, they are mechanically identical including fluid capacity. so 6qts should do it for you.
Old Apr 26, 2018 | 06:06 PM
that_guy's Avatar
that_guy
And just in case he doesn't know (I don't either with the 5/45rfe), does he need to check the fluid level in neutral like with the 44re?
Old Apr 27, 2018 | 06:18 AM
shrpshtr325
THE ULTI-MOD
i believe so, also check it with the trans warm
