New member, 03 durango r/t wont switch from a/c to heat
Old May 17, 2018 | 11:15 PM
Andrew Bump's Avatar
Andrew Bump
Default New member, 03 durango r/t wont switch from a/c to heat
I have an 03 r/t durango, problem is it wont switch from heat to a/c. I took the bottom blend door motor off (dual climate) it rotates only when going to heat. It wont rotate when I go back to cold. Not to entirely sure where to go from here. Anyone had an iaaue like this and also have a solution? Main controls bad or blend door motors? Wouldnt think both would be bad?
Old May 17, 2018 | 11:17 PM
Andrew Bump
This is her. About to turn 120k miles.
Old May 23, 2018 | 03:35 PM
If it only turns in one direction, it's likely bad.
