Popping/grinding in 4WD
Old Jun 4, 2018 | 09:43 PM
Jonjess94's Avatar
Jonjess94
Originally Posted by JeeperDon
Verify exactly what is wrong first. Don't just make a good guess and whip out your wallet. Crawl under and do an inspection, wiggle things, put the drive shaft on the bench if you can't tell while under it. IF it is the CV, someone else here looked into it last week. I remember seeing a CV for a Durango front at O'Reilly's for $155 or so, just the end joint.
Wrong I can get the whole CV axle and joint for less than $60, but thanks.
Old Jun 4, 2018 | 09:46 PM
Jonjess94's Avatar
Jonjess94
Also I just crawled underneath and found out that the joint is really jacked up and leaked a bunch of lube grease which most likely messed up the whole joint.
