Popping/grinding in 4WD
Old Jun 4, 2018 | 08:36 AM
Jonjess94's Avatar
Jonjess94
Default Popping/grinding in 4WD
I have a 2001 Dodge Durango that makes a loud clunking popping banging sound that is more pronounced on the drivers side when put in 4WD hi or low. Does anyone know what that might be and how much the part might be?
Old Jun 4, 2018 | 09:09 AM
Are you driving on pavement in 4wd?
Old Jun 4, 2018 | 10:50 AM
Jonjess94's Avatar
Jonjess94
Default Driving on pavement
It does it driving on pavement or gravel in 4WD and it doesn't matter if I'm in drive or reverse.
Old Jun 4, 2018 | 11:09 AM
Shouldn't be in 4x4 on dry pavement, at any rate, you will need to inspect the drive shaft CV joints.
Old Jun 4, 2018 | 11:48 AM
JeeperDon's Avatar
JeeperDon
Don't use 4wd unless 2wd doesn't get it done, and NEVER on pavement, wet or dry. A regular transfer case in 4wd locks both drive shafts together, always turning at the same rate. When you are in a turn though, the average distance the front tires travel is greater than the average distance the rear tires travel. Something has to give. It's not a problem on slick surfaces and loose gravel where one tire can easily slip a bit. When all four tires have good traction, u-joints usually break.
Basically, you're abusing your truck and are complaining that it it is complaining.
Old Jun 4, 2018 | 02:51 PM
Jonjess94's Avatar
Jonjess94
Default N
not abusing. I know about that. I don't ever turn on pavement with it in 4WD I just checked it out when it was still winter and the roads were really icy. That was when we first got it. I'm just trying to figure out what's needs to be fixed.
Old Jun 4, 2018 | 03:42 PM
Start with what I mentioned above. Being side specific, it's more than likely a work CV joint.
Old Jun 4, 2018 | 04:08 PM
Jonjess94's Avatar
Jonjess94
about how much for a CV joint?
Old Jun 4, 2018 | 08:01 PM
Don’t know. Check rock auto, eBay or your local parts store.
Old Jun 4, 2018 | 09:14 PM
JeeperDon's Avatar
JeeperDon
Verify exactly what is wrong first. Don't just make a good guess and whip out your wallet. Crawl under and do an inspection, wiggle things, put the drive shaft on the bench if you can't tell while under it. IF it is the CV, someone else here looked into it last week. I remember seeing a CV for a Durango front at O'Reilly's for $155 or so, just the end joint.
