Advanced factory cam
Old Jul 10, 2018 | 06:09 PM
tshephard's Avatar
tshephard
Default Advanced factory cam
Above from Cam Calculator... 1st and 3rd columns are factory cam.
I'm gonna' take a chance, I've done my homework!
I still have my factory cam in '99 5.9 magnum Durango. I put the specs in a cam calculator and it really didn't look too bad. If I advanced it 12 degrees it looked a lot like a cam in bewteen Comps' 254 and 264 cams.
So...., I already have the 4 degree timing set, if I advance the cam gear 1 tooth that's +15.65 (720 crank degrees / 46 teeth), then back up 4 crank degrees with the timing set (-4 = 11.65).
Is it possible they tried to give us a decent cam, and the emissions guys just had them spin it backwards until it came in spec?
I'm also thinking since 254/264 are higher cams with no valve/piston concerns (just springs), I'm good for any potential clearance problems (the stocker will still be at only the stock .410).
Did I miss something?
Old Jul 14, 2021 | 10:32 AM
tshephard's Avatar
tshephard
I got it in/done.
Using the Cloyes +=- set....
I was advanced 4
Set back to -4, then advanced 1 tooth.
Intake Centerline came out to 106, so now 3.5 advanced!
Waiting for oil pump, etc to start up.
Old Sep 1, 2021 | 05:19 AM
tshephard's Avatar
tshephard
In case anyone is following along...
I'm about 300 miles out, and the takeoff - say 0-30 mph shows no change.
But, I swear I think the 60mph range is using less fuel - just a bit - as my routine local runs seem to be a mpg higher at speed.
Almost makes sense if I moved the 'power band' lower (say a bit towards the 2K or so for 60mph) that maybe I gained a bit of efficiency (torque) in a lower RPM. I would gladly give up 5 HP on the top for 1 mpg in my interstate range.
Old Sep 1, 2021 | 10:57 PM
that_guy's Avatar
that_guy
It's not gonna be definitive, but if you find a download of desktop dyno out there and plug in everything for the motor and cam it should give you a decent idea of where the power moved.
Old Sep 2, 2021 | 11:06 AM
tshephard's Avatar
tshephard
If that's the one I'm thinking of, I tried to try it before I did it.
It wanted sooo much detail (head volume, for instance, that I just wasted a bunch of time researching data that wasn't gonna' change.
