1998 Dodge Dakota code PO420
Old Aug 26, 2018 | 09:55 PM
Appleblossem's Avatar
Appleblossem
Default 1998 Dodge Dakota code PO420
What does this code mean PO420
Old Aug 26, 2018 | 10:18 PM
primem's Avatar
primem
catalytic convertor efficiency code.
the code sets when the bank 1 pre and post catalytic convertor oxygen sensors start switching(high to low voltage) near the same rate.
this monitor test is run to check the function of the cat. When working properly, the front 02 should switch quickly, the rears should switch slowly. So the exhaust may have a leak, the 02 sensors may be bad or the convertor is no good.
If any other codes are set...post them in case they are related.
